Ok I’ve come to the experts for some info
I want to replace all the brake lines on my 69 bee and it’s a manual drum/drum brake system.
Gonna convert the front to 11.75 discs have the 15/16” bore manual drum/disc master cylinder and need a little info on the best kit to use while replacing all the lines. Would it be best to install the the same manual drum/drum line kit and find the right flex hoses for the calipers or is there a better option out there I should look at? All the parts are factory mopar pieces and the calipers will be rear mounted due to the sway bar interference.
