33 IMP
- 12:34 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
Well, the cap and rotor sure are! I don't know yet about the points and condenser.
When you have 30-32-34 dwell what’s the gap? I will say setting GM points dwell is nice with the window in the cap. Seems these you need to try different gaps to get to the dwell. I was at 26 and I closed the gap .001” @ .016”and it went to 28.
This is my first one of these carbs and if the floats aren’t right out of the box then it’s likely running out of gas. I assume when they’re low?
EXCELLENT GRAPHICS....one additional item to CHECK....MAKE SURE the float's pull clip is installed. Thus is an often overlooked part. It attaches to the needle valve stem AND the float's arm near the pivot pin's "ears". The purpose is to insure the needle valve starts to open as soon as the float starts to drop. This little item helps to maintain a constant fuel level and accurate metering.I'm not exactly sure what the point gap is mainly because I don't use feeler guages. I'll eyeball the gap, hook up the dwell meter, hook up a remote button to the starter relay and crank the engine. This is with the dizzy cap off. Then open or close the points to get the dwell you want. It's much easier than using a feeler gauge and the most accurate.
Yes, if the float level is too low the carb can starve at WOT. I believe the setting is 9/16". I'll try to find the diagram where to measure to.
It's 7/16". Using a drill bit works the best.
Like Bob R mentioned, check float drop also. 15/16" to 1"
I’ll report back once it’s all fixed up and let you know what I find. I would really hope Hughes isn’t selling ‘high performance’ lifter that hold open at 4500 RPM with only .050 preload. Hughes seemed to be of the opinion these lifters would run to 6500 with no problem.
My opinion is when you find the problem, it will be relatively simple. You are methodical in going through the systems, and have not skimped on quality components. I can't say what you will eventually find but I'm staying tuned. Best of luck.I’ll report back once it’s all fixed up and let you know what I find. I would really hope Hughes isn’t selling ‘high performance’ lifter that hold open at 4500 RPM with only .050 preload. Hughes seemed to be of the opinion these lifters would run to 6500 with no problem.
One question I wanted to ask was what preload are you using. Now I know. If all else fails and you happen to have adjustable rockers you could try .020 That's what I'm using.
Yes lifter pump-up is what I was suspicious of, not collapse.
I would double-check that your .050 preload is okay for those. I thought those were supposed to be run closer to .000 preload (but I could be thinking of the other non-standard hydraulic lifters.)
You’re right about the exhaust, thought of that the other day. I’m running manifolds and I know they’re clear and the heat riser is gone. Then it’s the factory H-pipe, I know that’s clear. From there it’s a pair of old Flowmasters and tailpipes. There could be some restriction in a muffler or tailpipe but I don’t get the noise from clogged exhaust. I’ve had cars in the past where the catalytic converters clogged and you get that restriction noise.What about a restriction in the exhaust? Are you running manifolds or headers? What about the cam itself - have they got any other grinds that top out power wise by 5000 rpm and you accidentally got sold the wrong cam? Just trying to think outside the box.
The first time I had this together I went a quarter turn which would be .025”. Same issue. When I spoke to Hughes they said they could be run at zero (race application only) but would be noisy. Cam card says close to .095, I questioned that and they said 1/2 turn is good compromise. On the 20 pitch thread that would be .050. I’ll run them at zero just to see if the fuel stuff doesn’t pan out.
I’m working on fuel stuff this week. I have the carb apart now with gaskets on order. Everything inside is bone stock for jets and rods and floats were not that far off. I think I was the first person inside the carb. Pressure are on the list to check.After reading this thread I believe it has a fuel delivery issue. As stated it doesnt miss, just wont pull at upper rpm range. It recovers quickly when the rpm drops. This would not any kind of valve train issue. No misfire tells me the it's getting spark. Have you done a volume test at the carb inlet? How much fuel will it pump in 30 seconds. Why a .600" lift cam fancy rockers with points and a stock style fuel pump?
Why is it a mismatch?.600 lift with 3.91 and 3500 stall sounds like a mismatch. But usually .600" lift would be up around 250@.050". To test delivery run the carb line into a can and run it for 30 seconds. I'd like to see at least a quart.
