TKO 500 Install - 1966 Coronet - SST Kit
Aaah yeah! Soon you too will be ready to pull out of the garage!
Here's a few pics of what it'll look like when it arrives...
that’s sweet ^^^
so i learned the driveshaft end will come with 1330 joints and SST will include the 1330/7260 combo
i have a 741 end and may up the pinion to 7290 for fun at some point - might not also
thanks for the pics of the driveshaft. always feels nice to have a new box come in.
watermelon
took some resistance measurements of original console backup switch in PRD321 and comparing to the resistance values from the TKO500. both matchup in that reverse shows a short while all others are open. wiring up backup lights now.
first pic from tko500
watermelon
0B40D5C2-EAA4-4125-84BF-DA664949699D.jpeg B6B9C873-1005-42EB-93CE-F44B13FF7A48.jpeg
31223F3A-6333-4EA8-BA2B-3E39DE50C861.jpeg 8887EAC6-9D56-41FB-A536-BCEBA6EEAFD8.jpeg 140BEDA7-BA2A-4886-A435-DAEDFC8C2229.jpeg 0B7CFC2A-CA6D-446F-91B8-5B7CDF917D7E.jpeg
driveshaft is coming in on Monday
i gotta hurry up and finish my cleanup efforts and plan to take a sick day Monday
watermelon
i’m leaving out the vent box and mounting my MSD Atomic EFI power box under the dash. it was in the engine bay area.
watermelon
C5F29BDC-7F19-4A94-A84A-625EBE54D7BC.jpeg C8B974F9-09A8-4405-BBED-8DEBE80C5EC3.jpeg
W H A T ???
i almost want to say the driveshaft box is the last one coming in that i’ll need to finish this conversion
you probably wouldn’t want me doing your TKO500 weekend swap for you
:lol:
watermelon
You missed the joke entirely.
Feels nice.
Box.
Come in.
:bananadance:
just FYI -the handle assembly needs to be drilled and have a roll pin slipped in. best to do on a drill press if you can. it can be accomplished with a hand drill and patience.
interior wiring cleaned up. console back in; all lines up nice. need to get rear seat back in.
driveshaft arrives tomorrow. i hope to meet FedEx.
pics!!!
watermelon
D2EA8FE3-3F84-476E-9F01-7AE4B7D53FED.jpeg A4682CF3-EA7E-4C43-AC53-5CC78C959BFD.jpeg B730D811-9BE7-48BC-84A0-1018F2B7EFFC.jpeg 5F14BC5B-46A8-41B6-A655-5588CD5D30C5.jpeg 654283D6-D4F5-4C92-B270-9805171D800B.jpeg C62920D3-5FF4-4861-8631-8D9074AC4307.jpeg
Oh yeah.... That looks super nice with your carpet, front seats and center console -with cup holds, in it!
driveshaft made it to me safe n sound. installed.
1330/7260 combo ujoint on the differential end
watermelon
D8CE6C33-26E8-49FC-9A1E-645D81CC8C77.jpeg 5AC12141-C1C2-4D55-8593-8B98AC3ACF27.jpeg 60965F60-7A17-4D06-9C7C-F164E957E160.jpeg C381E56C-C5EF-4569-A526-4146A350C205.jpeg 131DE0D4-8AA7-427D-8E32-C580C6E455E3.jpeg
How is the shift feel? Short throws?
haven’t driven it yet. playing around with it up on stands, yeah feels like short throws. it just clicks into gear. clutch should release if pedal is pressed in about 1/2”; i watched the bearing push clutch fingers in
watermelon
exhaust got more heat treatment today. used two rolls of Heatshield Products Armor to wrap. i think i used Heatshield Products for the flowmaster 40’s too but don’t recall as it been a few years; looks the same
ready to go back in the car
watermelon
20C87912-8178-4713-94F4-83BC35F33B39.jpeg 1266B70B-FA29-4731-8205-EE0C2562F8EE.jpeg 272DAA6A-01AB-430E-A85A-227E8D8B7D33.jpeg 1088EEC3-9884-4CCB-9BF6-A27B6318E2A4.jpeg 46E451AC-BC85-4E7A-9351-01693B5C2E2D.jpeg
well all my fancy wrap for my exhaust was all for not...the exhaust will not fit back in the car. the reason is that the new driveshaft is way over beefed. the larger diameter does not like the tight h-pipe and everything is trying to occupy the same space at the same time. driveline looks good once car is on all fours it’s just the exhaust was built around the original pencil-like driveshaft.
uggghh....i'm thinking i’ll cut the exhaust just after the turns from the engine and tack on some bullet style mufflers. i want to drive this no matter how loud it is.
don’t really feel like posting pics of this
watermelon
DD33113B-CCE5-4596-82C1-5897588D6445.jpeg 4029ADDD-F708-43F3-A6C9-67387C65A361.jpeg EA899926-B3CA-438E-869E-FDC6A6F495CD.jpeg 2A9C302B-1B41-4701-A7F8-9C621E477B35.jpeg
Well that sucks! Can you delete the H-Pipe and then cut/angle the pipes just down from the headpipe on each side to bring the exhaust out slightly and clear the driveshaft?
woke up thinking i’ll get some flanges and weld up a stack to create a safe gap just to get the car back on the road. the gap was less than an inch from manifold to exhaust and didnt appear noticeable from outside the car. we’ll see
watermelon
Now that's a creative idea! Hence Stephen's sentiment... "It's always a project!" You'll figure something out Melon.
found a couple of lengths of the exhaust tubing for the tailpipe area that used to run along the gas tank; chopped them off to accommodate the Hotchkis rear sway. glad i kept them in the garage for the past...ohhh...six or sevens years
i hope to work some magic with them
:praying:
watermelon
