My new project 1974 charger 318 se
Ok got it all back together and the starter still isn't engaging the torque converter
I would double check to make sure the gear on the starter is getting pushed out to grab the converter. It may have been failing this hole time drop on ground have someone hit key see if the gear jumps out towards the cone
I will in about an hour and ill let you know. Its to hot out there at the moment
Ok found these paper clip looking things at the bottom of the bell housing and coming out of the starter
Why do much I think a duralast one from AutoZone I'd only $50 or so life time warranty
Ok got the new starter and went to start it and lost spark...ballast resistor burnt up...got a new one now she starts and runs so I put her in neutral and let her Idle for 2 minutes and the fluid level hasn't changed......what now????
Well the pump might be bad . It should fill the trans up more then that though
Pop your trans lines off the rad maybe you have an air pocket?
Force feed the fluid in after lines are off ! Give it a little air blast with your compressor
