- 12:57 AM
- Jan 29, 2018
- Midland Ontario, Canada
Four hours later.. OP is just ******* with us..
That's been suggested about a dozen times already. We're not making anything "waaayy too hard".You guys are making this waaayy to hard.
Something is wrong with the tires or wheels. Find the problem! I vote he has junk tires.
The balance job sucks but that’s not the real problem, it’s just a sideline.
Man, you have just GOT to learn to get out of your shell and say what you really think....Four hours later.. OP is just ******* with us..
We aren't making this hard. The dumb *** that attempted the balance is making it hard. By stacking too much weight opposite the heavy spot on the tire he needed to compensate by adding more weight on the opposite side. Yes, there could be a bad rim and probably a bad tire. It's all about doing it right from the start. He was obviously trying to static balance the tire.You guys are making this waaayy to hard.
You don't suppose the pic is staged, do you?
OK. First answer.. no this is not "staged". Not sure what to think of that response.. ?moparedtn?
Second.. I tried several times to have the balancer 'tech', put weights on the OUTSIDE of the wheel. I believe he has been taught NOT to do that.
Backline: Again, this is what resulted after I peeled the weights off, spun the tire 90 degrees, then had it re-balanced.
My dad taught me 'back in the day' not to spin a tire more than 90, right or wrong. That's why I asked if you can turn the wheel 180?
I honestly can't remember what brand they are.. I can look after I get some coffee.
Yeah, well, the firestones are over $100 cheaper each, than the goodyears in the size i need.Well he did buy Firestones! LOL. Not a thing wrong with my Goodyear Raceway Redlines..
If the balancer tech refused to put clamp on weights on the outside where they would belong, why did you even let him do it ? He was trained to do it wrong ?
