biomedtechguy
Accelerati Rapidus Maximus
- 12:34 PM
- Mar 28, 2014
- South Louisiana
I would like feedback from anyone using electric fans, whether a single or dual fan setup.
HOW HAVE ELECTRIC FAN(S) WORKED FOR YOU? ANY PROBLEMS?
I find it very hard to believe that the company, Cold Case/Max Performance, that makes a fine quality aluminum radiator would sell a dual 12" fans and aluminum shroud assembly that doesn't work. After making sure everything was working properly and there were no air pockets in the cooling system, I was still seeing temps over 220° in my wife's GTO.
I got with the vendor that sold us all kinds of stuff for both of our cars, and he recommended a 16" two speed fan and shroud assembly, rated 4.9 out of 5 stars, over 70 reviews. I also have the 17" version for my Roadrunner, and soon I will see how it works to keep my 440 6bbl cool. I got Cold Case radiators for both cars.
I tried the factory mechanical clutch fan without the shroud on the GTO and it seemed to run cooler than the dual 12" fans, and that's when I decided to get the 16" fan. The problem is that I didn't take the car on the highway w/the mechanical fan, because that's where it is overheating. Everyone says at 40 MPH or higher the fan is no longer in the equation anyway.
Bottom line is I can't believe that the fan I have in the GTO now, so highly rated by over 70 people, the only brand that this very busy, very knowledgeable vendor sells because he never has any problems with them from customers, is the "second fan and shroud assembly that is so crappy" IT is the reason why the car overheats! No way!
I am convinced that the gap between the water pump impeller vanes and the divider plate (crazy Pontiac design) is too big, and that is causing the pump not to work properly, especially at hjgher RPMs.
