Topping out at about 90mph
Spicer shows 3300 RPM's will get you about 70 MPH...
https://spicerparts.com/calculators/transmission-ratio-rpm-calculator
with the 3k stall was it the same
Tranny is new and converter was just put in this week. Changed it from a 3k stall converter. I can feel all 3 gears kick in.
no I mean the rpm the same with the gears and speed and tires?
Yes top end speed has been the same with both converters. Have not tried swapping to taller tires yet. I figured id ask here and see if someone had any other ideas as to why I'm leaving so much on the table.
A 275/60/15 tire is 28" tall. Just sayin'.
Do you actually have a tach or are you going by a calibrated ear? < sarcasm. Hopefully you have a tach. I had a 440 that wouldn’t rev higher than 5500rpm. I switched from manifolds to headers and it’d go to 6300ish. You’re not running 2-1/2 exhaust with conventional mufflers or something crazy restrictive like that are ya?
Open headers at the moment, and i do have an aftermarket tach.
