- 11:52 AM
- Apr 13, 2012
- Granite Bay CA
I should have mentioned toward the start that there will be some stuff covered here that may be unique to this car and not necessarily something that you will encounter if you decide to install one of these kits.
Sorry if some of the posts seem boring or fundamental. I'm just trying to be as complete as I can in the hopes that it might save someone some frustration down the road. I am a big believer in wanting to know all the information up front so I can be ready or at least ask someone who might have a "workaround".
Yesterday was a lazy day but I was back out there today.
The hydraulic clutch master cylinder now has clear space to be bolted up. The wiring that was in the way has been relocated to go through the firewall in other places that turned out to be better anyway. The clutch and brake pedals are in so here we go. No more obstacles, right? Heh heh heh...
Old picture below but do you see that 3/16" thick flat lever on the column? For the 1970 model cars, It is part of the steering column lock. It ties in with the floor shift linkage so that the ignition key cannot be inserted or removed unless the automatic cars are in PARK or the manual trans cars are in REVERSE. This 5 speed swap uses a transmission with internal linkage so there is no way to integrate the system to the linkage.
I would just leave it if it weren't for the interference it poses for the clutch master cylinder:
Oh well....I didn't need it there anyway.....
