- 10:45 PM
- Sep 5, 2017
- 6720 Cuff Road Jackson, MI 49201
Trunk lid is on, grill support is on (still needs blackout), and the doors are installed and adjusted. The driver door was spot on using just the drilled guide holes. The work on the hinge pins did not affect the alignment. Not bad for being on the car almost 50 years. The passenger door pins I didn't have to do anything with but when hung, this door was off a little. It was a touch low and the bottom stuck out just a bit. I can't say it wasn't like that from the start as I guess I did't pay too much attention to it, other than checking that the pins were tight. A little adjustment and the door fits pretty well. I made one small mistake. I should have painted the black on the inside of the doors before hanging them. I thought about it but I didn't want to put the finished side of the door down on the stands. So now I created a little more work for myself as far as masking.
