sabre67
Has any one here used a set of these or hear of anybody who has? Just curious (790.00 a set complete).
How was the geometry using those rockers and TF headsI have the 1.5’s on a 505 with Trick Flow 240 heads. No problem at all, just make sure you get the correct mounting kit for the brand of cylinder head your using. I prefer these rockers because they’re made with bushings instead of roller bearings. Roller bearings are okay but the bushings don’t hemorrhage as must oil during operation.
So, the Hughes stud kit shows to be 2.375" in length. Others have reported them only coming about halfway through the nut with the stud fully engaged. Hughes says "if you need more engagement just back the studs out a few turns"...Horse hockey! The whole point IMO of studs is to get maximum depth in these heads due to them not having steel inserts.Did anybody use the stud kit available from Hughes to mount their rocker shafts? Thanks you have all been a great help
This is exactly what I want to run, can you post the item numbers of the rockers, lifters and push rods you’re using? Thanks
Okay for some reason I thought you were using TF....I think I got cornfused by another post lolIm going to be using Edelbrock RPM heads so ill be sure to check my height with the Hughes stud kit
