Canadian1968
I did the hide away HEI module conversion on 68 Charger with a mild built 440 . There was nothing wrong with the Mopar orange box / ignition currently , just more or less something for me to play with that is SUPPOSED to offer a strong more consistent spark.
Here is what I did.
Dug out the the inside of an extra orange ecu Box I had. Clipped the ends off the transistor that sits on top. Soldered some new wire wires to the pins of the original orange box harness. I am using an ACDelco HEI 4 prong module. Wired it up correctly, and the fastened it to the orange ECU box by running a bolt threw the HEI module mounting hole and then threw to original mounting hole that holds the transistor on top of the mopar unit ( USING ALL THE THERMAL COMPOUND offered with the module) .
I hollowed out an extra ballast resistor I had , and connected it with 10 awg wire and then filled it back with some putty epoxy.
Coil is a Summit E-coil (850615).
Regular Mopar electronic Distributor
Made my own coil wire with a Taylor Kit for the coil to distributor.
Problem is, car seems to run fine until it warms up. Once warm the car will just die randomly sitting idle . It will die just sitting in park, and doesn't seem to like when I throw it in drive, will bog down , not always die, but it doens't seem to like it.
I just got a new coil from summit , the first one I got had something rattling inside I figured that was my problem. But this brand new one does the same thing, so that can be it.
Thoughts suggestions......
At the end of the day, I will just throw original stuff back on, all plug and play which is why i did it. BUT I like to know what this isn't working...... Thoughts?
Here is what I did.
