SMS68
yes, the case will work fine. There are many combinations of internal components for different years and different applications.
Thank you. Next question would be what is a rebuildable small block 727 case worth these days?
$100-175 bucks...Thank you. Next question would be what is a rebuildable small block 727 case worth these days?
Thank you, but all FSM are not available on that site.Tom can't help you with the rest of your car... Get a Factory Service Manual. I left you the link for free ones...
know this doesn't help you right now but for others this is a perfect example of why you should have a service manual for anything you plan on taking apart.
Get on line and check Youtube videos.
http://www.mymopar.com/index.php?pid=109
I have been searching for a 1977 dodge truck FSM. A digital 1963 Polara FSM would be nice, I would hate to ruin my original paperback.Ironbuilt what FSM did you need ? Year/make/model ?
May I ask what is FSM?Thank you, but all FSM are not available on that site.
Thank you for the info.Factory Service Manual
Used to use type f in my 70 charger 500 440 looks like there were a few different you could use. To answer about the fluid lvl you are measuring the top so if do a deep pan with a filter extension it is still the same full mark on the stick.Awesome post!!
Quick FLUID question..
I have an A12 car, still running the 6 pack & 727, had a shop repaint motor due to a small fire, they "Added Fluid" to what was in it. ATF+4 I'm told. Has had the usual leaks etc. My dad put a deeper (2 3/4") deep. Not sure if getting right advice, recently seen that MoPar says "Run ATF4 in it no matter the year".. Ok, but I don't care for the Synthetic higher psi probably causing most owner's leaks?
CAN I RUN Dexron II/MERCON in it w/o any problem? Thing is completely drained, converter and all. Just installed the correct 38 tooth gear for 28" tires (4.10 Dana 60). So before I go reinstalling pan etc, I noticed this shop used RTV silicone between BOTH pan and case. I have always thought that is a "No No"?
I'm surely not getting a correct fluid level reading when "Hot in Neutral", and recently came across a post regarding a FILTER EXTENSION. Now, I'm thinking I need to wait.
Any help GREATLY appreciated!!
Gasket is the Global Trans parts "4014C, A727/A518/A618/48RE" 4.5mm thick gasket.
Thanks!!!!
Not sure the question there are so many brackets seems like you are working on the kick down for the transmission?Lokar throttle cable, what else will I need here or are the factory brackets enough? Note I haven't researched prices on this cable kit is the reason why I used the eBay auction.
https://www.ebay.com/itm/294084764764
So kinda doing the same thing on mine now did look at that cable. I have the factory solid that probly going with. Advice would be brackets are easy to buy and make have it straight with your throttle linkage and be able to adjust from the pic the lokar has that . Best of luck keep kickin ***.Kick down yes.
Interesting so the 727 is a good transmission?Often I or anyone for that matter asks to find out what type of transmission they have in their old mopar. There are hundreds, if not a thousand, of threads on this website identifying, discussing or assisting with this process, troubleshooting or repair.
Because of this large number of threads and the fact that using the search option is unbeknownst to some members, I have put this together.
FIRST AND FOREMOST, HERE IS FRONTAL PICTURES OF THE /6, SB, AND BB TRANSMISSIONS:
HOW TO IDENTIFY YOUR TRANSMISSION:
1. Do I have a 727 or a 904?
The picture of the 727 transmission is first, the second is a 904 transmission –
Gasket pictures to see what you may have from a bottom view
2. Here are pictures of 4x4 transmission 727 on the left and 999 on the right
3. Where do I look for the identification number’s on my transmission?
You will see a set of numbers starting with “PK” on the driver’s side of the transmission above the tranny pan but below the shifter levers, see below:
The passenger side carries with it (if its 69 model year only) the complete VIN of the vehicle, 1970 and above have the year, place of manufacturer, and serial number of the vehicle it was made for, see below:
4. What are the differences between a A518/46RH, a 904/999/A500 and a 727?
5. What do I have to do to put a OD transmission in my older vehicle?
Here is a start. There are many sites that cover this swap, but this one is pretty good to get you going.
http://www.transmissioncenter.net/SwapInformation.htm
6. Why is a 727 called a 727 and a 904 called a 904?
The 904 was originally called the Torqueflite 6 and the 727 was the Torqueflite 8. These designations were changed in '64 when the 904 was adapted for use in the new 273 V8 and was no longer a 6 cylinder only unit.
7. What is the difference between a truck and a car tailhousing?
TRUCK HOUSING:
CAR HOUSING:
8. What is the difference, externally, between a 65 and below 727 and a 66 and up?
65 and below will have the parking brake mechanism located on the outside of the tailshaft housing (see right silver transmission), and the transmission mount is located in a difference place, and has wider bolt/stud mounting holes.
Also, 65 and below were a pushbutton design:
9. What are the differences between the shift levers, are there any?
Generally, a 727 shifter lever is straight and a 904 is offset (though some applications have different length of levers to compensate for vehicle model/engine combinations).
727 on top, 904 on bottom:
10. This will give you an idea to the different styles of throttle pressure (aka kickdown) levers:
11. Good reference on what each port does in the transmission case:
12. BREAK DOWN OF A 727:
13. DIMENSIONS BETWEEN 727 AND 904:
Remember, only smallblocks have 904 derivative transmissions, though some came with 727’s (i.e. certain truck and HP car models). Big Blocks only came with 727’s.
And here is a kicker to boot.. International Scout’s and other IH trucks used 727’s also.. so did AMC’s here is a pic of a AMC 727:
Great resource book:
http://search.barnesandnoble.com/Torqueflite-A-727-Transmission-Handbook/Carl-Munroe/e/9781557883995
WELL THAT ABOUT DOES IT.. HOPE YOU ALL GET A LITTLE INSIGHT FROM THIS.. I MAY ADD TO THIS AS I GO ALONG.
If you're asking that question, you MUST be new to Mopar!!Interesting so the 727 is a good transmission?
