Fuel Gauge Street Tee
BeeFast
9:07 PM
Nj
I want to install a 1 1/2" fuel pressure gauge (1/8 NPT) between the six pack lines and the fuel pump line where the two connect next to the outboard carb. I can't find a street tee adapter for this. Where can I find such a piece? I've searched but ran out of avenues.
Flare in and out with a NPT tee for the gauge, is that what you're looking for?
Maybe drill and tap the first tee in your set-up for the gauge.
Try brass Weatherhead fittings, inverted flare type.
Then use a coupling to connect your gauge. Use b4 the first tee.....just a suggestion...
BOB RENTON
Thanks for he suggestions.
