Which Engine Paint do you like?
Was going to try Bill Hirsch's paint, but...... i couldnt find either of the pre-68 hemi oranges, the race hemi yellow-orange, or the first version less-red street hemi orange.
Search for good stuff continues.....
I use KBR high temp. They specialize in that stuff.
Looked at Kbs a little better, after Hirsch had nothing. KBS at least has the race hemi orange i need, and has a paint system of products. Gonna give them a try.
(Even less expensive than the three garbage spraycans i got from mopar!)
Thanks @tmaleck !
T, did you buy direct from KBS, or a dealer?
Epoxy primer VHT High Temp over a thoroughly cleaned block. Two coats then VHT Hemi Orange two coats. Have not run it yet so it might not hold up, we will see...
Thanks @tmaleck !
I bought direct from KBS. They shipped out pretty fast. I'll agree with Hemibee the primer is key.
I have a 383 out for repainting and fresh heads. I could use some feedback from those who have had success with engine paints.
I haven't had much luck with the VHT spray. Even with a fresh block washed and degreased engine block. Eventually it bubbles and flakes.
I met someone recently that did like the POR paint. I also saw a YouTube on epoxy engine paint?
What would you do if you had to paint an engine that could not be dipped because I am reusing the assembled short block?
Any advise for prep and paint?
Thanks in advance
KBS Motor Coater Engine Paint Kit used here.
https://www.kbs-coatings.com/motor-coater-kit.html
Another vote here for epoxy primer and KBS.
2 coats each-sprayed.
I used VHT on the headers. Works good, but you
have to burn it in. Turns to a light bronze with
heat
