Challenger340
- 3:09 AM
- Mar 4, 2014
- Moyie Lake, B.C. Canada
The old 440 domed trw/sealed power L2295 had a compression height of 2.029. It was a compression height that doesn't make much sense for a custom 440 piston.
why did TRW do a dome so far down the deck
we always had to deck the block .055 or so to get the pistons closer to 0 deck.
The best reasoning we came up with is trw used the ch of the 68-69 375hp engines and then added the dome and the valve reliefs.. just a theory any way
but if that were the case...
67 replacement would be 1.99
68-69 375hp 2.029
The reason the L2295 Domed Piston was built the way it is(approx .050" down Hole at TDC).... is that it was designed to "act" like a Flat Top at "0" Deck for Compression purposes without the Piston to Valve issues a true Flat Top @ zero deck would entail..... and back in those days cooling/quenching was not a consideration with the better fuels available.
For all intent and purpose...
The DOME volume ~ 12 CC's on the L2295 is the same as if you just had a completely Flat Top Piston @ Zero Deck
We used to mill the Dome off the L2295, drill lightening holes up under the Pin Bosses, and add a set of the lighter "std" piston pins to get them down in the 900's weight-wise.... then as you said we would also Mill the Blocks .055" and run'em under some heavily Ported/Milled 915's to get to 600 hp with a Solid Flat Tappet Cam.
Those were Budget years for sure....
