*I know it's a different animal
I'm not anti-carb, or anti-EFI either,
both have their place & their own technology, pros-conns
in fact I think everyone should own & drive a
2 x 4bbl or a 3 x 2bbl be-it EFI or Carbs
(especially Holley 4500 Dominator/1450 dual feed or split-carbs &
2300 series Holley style/6bbl-SixPack, Quikfeul is my personal preferences)
personally, on a NA engine WOT, drag racing application
(even roundy round/Nascar, made slightly more power with carbs)
I think the properly tuned Carb can make more raw HP
the ability to tune/change the 'fuel map' on the EFI
at every RPM range & at different timed increments, not just WOT
aides some fine-tuning too
(Drag racing is pretty much WOT all the time)
I ran mechanical Fuel Injection in drag racing
& Sprint cars for decades, usually alochol/methanol, a lil' hp boost
keeps engine cooler too, especially boosted/blown
straight comparison dual carbs 2 x 1,500cfm = 3,000cfm flowing
or 4 x 2bbl 750cfm/split Dominators, each carb opening more or less
sitting over a cylinder port on the fabbed or aftermarket production intake
or Stack FI flowed depending on stack length/diameter
2,200-2,400cfm average (BBC Crower)
or a hat on a Tunnel Ram
with an Enderle Bug Catcher Hat 2287cfm flowing (or 4 port Hilborn)
you can get a bit more cfm, by knife edging the butterflys
& recessing the screws etc.
(even though less cfm than the 2 or 4 (split) Holley Doninator carbs,
but better fuel control, more constant flow, increasing with RPM
180a pump managment/pressure with bypasses & pills or nozzle changes)
I saw a 0.15 to 0.20 et improvement over carbs, exact same combo
Enderle Bird Catcher 4605cfm flowing
(good for Blown Alcohol or just big cid NA alcohol/methanol)
Enderle Buzzard 5994cfm flowing
(all out Big CID Gas or Alcohol, Fuel Hemi's, until about 2010)
*Albeit most here will never-ever see
1,350-1,400+ hp NA on a 4.60" bore 3.75" stroke
or let alone 10,500+ rpm levels, or 1" valve lift 500cfm ports flow
it's an example, to look at EFI vs Carbs
*NHRA Pro-Stock has switched to EFI since 2016
just now 7th year in, running them
and with great RAD/mineshaft air (200' below sea level RAD)
& track conditions
they are just now almost caught up/only this year's 3 races in
at the Gator Nationals to the ET records 6.46-ish
(IIRC 6.455in 2015 with carbs @ 215.55 in 2014, MPH is raw HP)
off the 4 x 2bbl Split-Dominator Carbs,
& they still haven't surpassed them yet
(a couple mph down currently too 210 vs 212+)
albeit they've also had a 10,500 RPM limiter now too...
Every well-tuned P/S combo is bouncing off the rev limiter at the stripe
But
It's coming around
the P/S guys were fighting it at 1st & most have now embraced it
I think NASCAR is the same, they are creeping up on it there too
but they've changed so many other things on the car
comparing 3 years ago to today is like
apples vs watermelons in comparison, are way different
if you like it go for it, if you don't like them, then don't go for it
not really an argument here
good luck, Happy MoParing
