JDmac72chrgr
@HawkRod : didn't bowl vent go to smog charcoal filter/vapor recovery system back in the day?
I just figured it out. It actually goes to the black charcoal cylinder to reclaim gas fumes. Luckily, I still have mine in the car, so one hose and I should be all set with that!If I remember correctly, and it's been about 30 years since I worked on these at the dealership, that vent went to the inlet breather on the valve cover. One valve cover has the pcv, the other has the inlet vent that attached to the air cleaner and it had another vent nipple coming out of that cap. One big for air cleaner and one small for evap vent. I could be wrong. It's been a long time.
So I think I mentioned a strange "thunk" sound that started from the front right of the car. I finally got my car back on the lift to check it out.
See something wrong with this picture?!?![]()
The nut, washer and bushing are gone from the rear of the upper control arm! The front nut is also loose, but that hadn't come off yet.
Was it me or the alignment guy??? (I remember tightening these, becuase pressing the bushings on was a pain, and we had to clamp the bar/shaft to tighten the nuts.) Sigh. I guess it doesn't matter because it has to be fixed regardless...
Luckily, I found the bushing at RockAuto, so I have a new bushing coming. I also found the big washer/ retainer still laying in the frame. But I don't have another nut.
I have another 5/8" nut (shown on the right), but I'm not sure if there is anything special about the factory nut (shown on the left)
Anybody have any insight about the nut? Anything special about it?
WOW …..Your car was very kind to you…. It kind of looks like the threads on the original nut may be either soft or starting to fold in if that makes any sense. I would suggest getting the complete eccentric bolt and nut kit and double check the other side and everything else as well. Pictures truly are worth a thousand words.
Totally agree. While I'm not happy about having to repair it, it is much better when I can have it on my lift at home, rather than busted down on the side of the road miles from anywhere!@HawkRod : THATS NOT GOOD!! Rather near home then on ROAD TRIP!!
A 73 is different than the earlier units, so it does not have the eccentric bolts, but rather a shaft that gets adjusted. I believe when it got aligned, the alignment tech did not tighten down the nuts that hold the washers and bushings in. So one came off and the other was very loose. The driver side is fine. Buy yes, you better believe it - I will go over each nut and bolt in the front suspension to verify they are tight and in good shape!WOW …..Your car was very kind to you…. It kind of looks like the threads on the original nut may be either soft or starting to fold in if that makes any sense. I would suggest getting the complete eccentric bolt and nut kit and double check the other side and everything else as well. Pictures truly are worth a thousand words.
I need more testing time for sure I go to work out these bugs!
My 71 was different, that's what I was recollecting. $.50 word right there.I just figured it out. It actually goes to the black charcoal cylinder to reclaim gas fumes. Luckily, I still have mine in the car, so one hose and I should be all set with that!
Hopefully tomorrow afternoon I'll have some time to start it and see how it runs.
Glove compartment!where are you putting YOUR stuff?
We are hoping that we can buy you (and your lovely wife) a beer and/or some dinner when we pass by ~mid June!Sounds like you're about ready for the launch pad! Good luck with fitting those storage bins in the trunk
and if you need anything in the midwest, you know where I live!
Damn straight! If you need some help around mid June Barry and I will gladly stop for a couple of says. Kind of like a mobile Mopar Garage Squad (except we 'ain't good looking and our skills are marginal...)!Right after WE roll the engine, trans, and K-frame under the "X"! Hey, you volunteered!
Ha! Going through the trans right now. Have to buy the Trans Go TF-2 and install and then
buy the convertor. Engine is done. Putting a steel 48re front planet in it and a 48re direct
drum in it with 5clutches and Kolene steels. John @ CRT is helping with parts
