Very nice. What power train are you going to install? Body color, and interior? You might have stated that before, I missed it.
The plan is to make a very reliable, fun and capable daily driver type car. Essentially everything will be new or redone except the exterior. It will have a air grabber hood and the 71 spoilers front and rear. Not planning on painting the exterior anytime real soon but when/if I do it will be B5 which is the original color. Here are some of the "details" for anyone interested
2019 5.7 Hemi crate engine
6.4 Cam and springs
TTI headers
Holley Terminator management system
TTI engine mounts
Remote oil filter
Holley front accessory plate with Holley 150A alternator, PS pump and AC compressor
Griffin 3 core radiator
Modern Challenger dual electric fans
Modified fuel tank - adding an in-tank fuel pump with a baffle
3/8 feed and return fuel lines with -6 AN soft lines (Fragola series 8000 push lock)
TKX 5 speed trans (kit from Silver Sport)
Silver Sport bell housing
Silver Sport hydraulic TB/clutch
Silver Sport clutch, PP and flywheel
Silver Sport trans cross member
Forward shifter location and will use the 71 mid length pistol grip
8 3/4 rear end (stock) with 3.55 SG
Modified rear springs with poly bushing in the front, solid on the rear
Firm feel adjustable front left hanger
Slider rear leaf supports (replace the shackles)
Hellweg rear sway bar
QA1 single adjustable shocks
Assassin traction bars
Rear disc brakes (have Wilwood but might go a different direction)
Wheel Vintiques black series 63 wheels with 295 tires (not sure which yet) with Dodge hubcaps
Modified stock K frame (welded with PS box bracing)
Firm feel front suspension components
Borgeson PS box
Hellweg front sway bar
Firm Feel 1 1.4 torsion bars
Modified lower control arms
QA1 tubular upper control arms
Front disc brakes (have the Wilwood system but might change direction)
Mopar 15x8 steel wheels (not sure the tire size yet) with Dodge hubcaps
Brake MC will be a Mopar unit
Building a hydroboost system
Hella headlights
Stock side and turn lights
First place auto front and rear spoilers
AMD air grabber hood
USCT subframe connectors and torque boxes
Homemade under fender braces and perhaps radiator core support
Stock front bumper and grille
Stock rear bumper and taillights (the non RT kind)
Ron Francis wiring harness (not sure if I am going use this or not)
Black interior
PROCAR seats (maybe, I have them but need to see them mocked up)
Mopar buddy seat
Stock glass (roll up windows)
Mopar tilt wheel (I have 2 and will try and get one to work)
Stock rear seat
Legendary door panels
ABC dash pad
Stock instrument cluster with tach (or Dakota Digital if they come out with one)
Classic auto UA-740 stereo
Kicker subwoofer
Kicker amp
6x9 rear speakers (TBD)
Dual 3.5 front speakers (TBD)
Vintage Air AC system
Stock rear window defrost system
Black sound deadener throughout entire car
Semi auto antenna
The exterior will remain pretty much stock with 1 red fender and such but we will see.
I am sure this is far more than anyone wants to read but hey, now its out there.
