Cheapsunglasses
In Rust We Trust!
- 12:57 AM
- Dec 21, 2021
- Miserable Smells TX
Let’s see how much we can get done before we’re done today
They are. I have 2" Hedmans on Fred and it's a pain to change plugs and such - and he doesn't produceI was looking at Dougs headers, 2” tubes seems a little over kill
Can you register the car with the bonded title? Mine has been out of the system since Nov 98 but it's been in my name.....since 88. The car I sold had a lot more rust on it than I wanted to deal with and if my wife hadn't been with me, I would have walked away from it when I first looked at it but she wanted it. Oh well.If your car has been out of the system for more then 10 years, you have to bring it to a theft inspector, once they run the numbers, you take it to the dmv, then you get a rejection of title, and some paperwork, then you get a bonded title, and 3 years later you get a blue title. It’s a real pain in the a$$, but it’s the only good way I’ve found.
Yes, I registered mine with YOM plates, and they also made a change, instead of a sticker on your plate, you can do a regular registration stickerCan you register the car with the bonded title? Mine has been out of the system since Nov 98 but it's been in my name.....since 88. The car I sold had a lot more rust on it than I wanted to deal with and if my wife hadn't been with me, I would have walked away from it when I first looked at it but she wanted it. Oh well.
I have a 68 plate too....but only one. Thing is my car is a 66 but think it would still be cool to to have it.Yes, I registered mine with YOM plates, and they also made a change, instead of a sticker on your plate, you can do a regular registration sticker
What size are your valves....uh the ones in the heads on the car....One guideline that I heard regarding header selection was to pick a primary tube approximately the size of the exhaust valve.
Many cast iron heads use a 1.74" valve...... 1 3/4" headers are 1.75 and 1 7/8" headers are 1.875.
I went with 2" because they were in stock and because I figured that at almost 500 cubes, it made sense.
Take pictures! Nothing helps the memory more than seeing it in a picture. Multiple angles with good lighting too.I’m out of gas, so that’s it for tonight. Only thing to do now is remove the z bar. I forgot how all that goes, so I need to do some research, and probably call someone with a better back.
Yep, I’m taking plenty of reference pictures, it should go back together the way it was…with just a few extra boltsTake pictures! Nothing helps the memory more than seeing it in a picture. Multiple angles with good lighting too.
All of my build threads have multiple pictures in my posts. I often go back to reread what I posted to refresh my memory.
