4mulas
- 12:10 PM
- Mar 16, 2017
- Just North of Great Falls
Hi there, don’t do much metal or body work so looking for what recommendations folks have for die grinder bits to enlarge my antenna hole. It was radio delete car that the previous owner put a radio in and aftermarket antenna. The hole is not what factory mopar antenna uses so I’m changing the antenna to stock and getting rid of the crappy aftermarket one.
fortunately the hole the made is near the stock location, I just have to enlarge it to fit the new antenna.
I can only think of using a die grinder or dremel like tool for this and would like recommendations on a good bit to use that maybe won’t create too much heat. I have both the die grinder and dremel.
‘’thanks!
‘’thanks!
