Great Guy
I always liked working on a car when almost everything I needed was in a neat pile for me to use. That's fun!!
that front grill,so many piecesMy pile 'o junk to go to the sandblaster. There's 14 pieces for the front bumper alone! The 1970 bumper and grille are far more complicated than the 68-69 Charger.
I'm sure there's more than one box?Dropped all 21 piees off at the sandblaster this morning. I also opened up all of the boxes I've received to check out what's inside.
I'm sure there's more than one box?![]()
QA1May have missed it whose front end kit did you order?
Just scriping no wire wheel and torch ? Mines a NY car with undercoating and I will be doing the same thing.Been working on my back this weekend scraping off undercoating where the subframe connectors and frame stiffeners will go. What a miserable job.
This side is completely clean View attachment 1450952
On this side I just have to clean the residue off with lacquer thinner and test fit the frame pieces.
Here you are RC being flooded with advice on how to do this (when you perhaps are largely done!), but I'll add my experience too:
My buddies 67 GTX was an undercoated car; really thick in some places. The car was gutted, so we used a weed killer propane torch and directed the flame on the inside floor of the car. This heated up the metal and loosened the undercoating where it was adhered to the underside. While still hot, then we used scrapers to scrape off the undercoating - but in spots it literally almost fell off. It really worked very nicely. There are some obvious places where this didn't work like frame rails and such where you can't get to the back side, but it really made the job a lot easier.
Whatever method you choose, best of luck. No matter what, it is a miserable job...
