josephqatarcarguy
things ive done so far
1. check for vacuum leaks - not any i could find
2. bump the timing up to 18 degrees - idles well but again seems worse when put in gear... goes down to 500 rpm and then dies from 850-800rpm
3. change advance springs to 1 heavy silver and 1 light silver
the car seems to run a bit worse in drive with the timing bumped up ..... any leads guys??
