3sloppydogs
- 11:29 PM
- Jul 19, 2019
- carroll county MD.
As many LED as you can. You will appreciate more light especially as you get older
Amen! Best advice ever!!!!!!!!!! Thank you EVERYONE!!!!!!As many LED as you can. You will appreciate more light especially as you get olderView attachment 1515411View attachment 1515412View attachment 1515413
Stay away from those type of fittings - the lampholders are prone to heat problems...and premature burnout.
True. I wanted a good look and quality lighting. I find it best to spend it once even if it may be more. For what its worth my 36 x 42 shop has 11 8 foot commercial fixtures and quality Sylvania florescent 8 foot tubes. I did this in 2000 and have only replaced 1 tube in 23 years.Your money to spend
Are you referring to placing lights on the walls too, like in paint booths?Also if you do lift make sure you put lights where they’ll cast under and not make hard shadows. As mentioned before, the more you have the better.
I agree,True. I wanted a good look and quality lighting. I find it best to spend it once even if it may be more. For what its worth my 36 x 42 shop has 11 8 foot commercial fixtures and quality Sylvania florescent 8 foot tubes. I did this in 2000 and have only replaced 1 tube in 23 years.
Here is something to think about if on a budget. Electrical contractors are always doing commercial upgrades. They are removing quality fixtures that are outdated and energy hogs. They end up in a scrap yard. These fixtures can be updated to LED'S. Point is if you ask around you might find them for little to nothing and do the upgrade.
Same thing me and a buddy did while working at the airport in ATL back in the 90s. The company leased an old Eastern airline building and renovated it for our use and threw away a whole dumpster full of 8" fluorescent fixtures. We hauled off 25 lights. Enough to do my shop and his both. I've been converting them to LED a little at a time. This happens all the time, you just need to be in the right place at the right time, and have a good connection.I agree,
That's what I did for the garage I built when I lived in Tucson. I bought used take out fluorescent fixtures from a store owner that upgraded their lighting. If I remember correctly, I bought (30) 4ft, 4 bulb fluorescent fixtures with bulbs for $5.00 a piece. I kept half for my garage and sold the rest for $10.00 each to guys at work that wanted to upgrade their lights.View attachment 1515702View attachment 1515704
Maybe i'll get lucky!just need to be in the right place at the right time, and have a good connection.
Voltage doesn't matter - ALL LEDs run on low voltage, the transformer is either internal or external. The nice thing about the external box is that electrical codes accept these instead of having to install octagon boxes. And should a light ever burn out, get damaged, etc they're a breeze to change.Look at the wattage and get the 110 to 120 watt ones,
No, I just plastered the ceiling. I use portable light if I need it. wanted to keep as much wall space as possible.Are you referring to placing lights on the walls too, like in paint booths?
Can never have too much shelving.No, I just plastered the ceiling. I use portable light if I need it. wanted to keep as much wall space as possible.
