Okay, thanks.
I doesn't surprise me as there is a lot on this car they do not reproduce or if they do, I cannot afford it.
Same with the ’69 although it’s a lot better than it was 25 years ago…
Okay, thanks.
Here's what was on there when I got it. There was only one side that had it.
Follow the link...I'm trying to find the 8-32 x 3/8" flat head screws that hood the 440 call out emblem in place. I see places selling them with the new emblems but not listed seperately.
Already ordered them. ThanksI guess the center doesn’t need to be open if there’s no Air Grabber. It looks kind of frail so finding used ones in decent condition would probably be almost impossible. If you just want to avoid paint to paint contact the one I posted last night would work.
Yes, I looked there but didn't see the correct head diameter. The originals were only 3/16" (.1875) and the smallest I saw listed were 5/16" (.312).Follow the link...
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
Extra info, reduced head diameter screws do exist but an 8-32 might be tough to find... Especially in black oxide... If you don't mind painting them it wouldn't be hard to modify a few standard screws in a lathe...Yes, I looked there but didn't see the correct head diameter. The originals were only 3/16" (.1875) and the smallest I saw listed were 5/16" (.312).
Trim parts sells the 383 call out emblems and includes a package of screws that look correct. Tried searching for just the screws but haven't had any luck yet.
Have you ever tried the Trizact system? My buddy who's done this stuff for 40 plus years likes to cut initially with conventional color sanding materials to knock down the biggest texture then change over to the Trizact DA paper..Wet sanding the clear on hood.
First round was with 1000 grit using a hard block (piece of Oak about 1 1/2" wide, 5" long and 3/4" thick). It is easy to see progress because the surface is dull with no shiny spots.
The second round is 1500 grit using a soft block. The goal is to remove all the 1000 grit scratches so I use 3M Dry Guide coat.
You can see how it highlights the scratches I missed.
I will do the same with the 2000 grit and then go to buffing.
Yes, however on this car I feel more comfortable doing it by hand.Have you ever tried the Trizact system? My buddy who's done this stuff for 40 plus years likes to cut initially with conventional color sanding materials to knock down the biggest texture then change over to the Trizact DA paper..
It needs to click twice... If it doesn't either the striker needs to come out further or the latch has an issue....I started installing the door handles and catch today but ran into a problem When I close the door it does seem to latch but has a lot of slack in it and the door will stick out 1/4".
I moved the catch in as far as it will go to get the 1/4" and then moved it outward to see if it wasn't fully latched and might pull in more. Nothing changed. That catch doesn't have a not of movement.
Any suggestions?
