- 10:40 PM
- Jan 29, 2018
- Midland Ontario, Canada
Also, if you slather it onto the back of an aluminum wheel, where it mates to the ferrous hub, it prevents the wheel from welding itself to the hub after a Canadian winter or two.
Actually, they are a "Hall effect" pickup. They create a frequency at specific amplitutde (voltage).On the ABS sensor testing... they are a simple ac voltage generator.. if you were Doc Browne from 1955 , you would hook up 4 ac voltmeters and drive/ watch for differences.
( or hope the new scanner will do it).
And as mentioned check resistance between sides.
If you can get at the connectors![]()
Already booked my flight to Japan so that I can kill some designer... here's the front connections where you can get one hand in to try and unclip them with zero extra length. Passenger side under the A/C lines...On the ABS sensor testing... they are a simple ac voltage generator.. if you were Doc Browne from 1955 , you would hook up 4 ac voltmeters and drive/ watch for differences.
Ah yes, could be. I was going by the tone ring vs encoder and the 2 wire connection.Actually, they are a "Hall effect" pickup. They create a frequency at specific amplitutde (voltage).
LOL...she has that available, just not until Spring!
If you travelled on the highway for approximately 3km or more (78 washing machines) at more than 95kph (59.5 wm/hr)
I looked at them close today and even pulled one out, they definitely haven't been hit at least.If your hubs were shot, they likely took out the speed sensors with wheel wobble. Contact between hall effect sensor and rotating mass is no bueno. I'd replace the sensors for the wheels that got hubs and go from there.
And yes, the wheel speed sensors send data to abs and traction/stability. Trans light is 99% a companion light, due to sensors acting up.
Does it have paddle shifters?I looked at them close today and even pulled one out, they definitely haven't been hit at least.
Nope, as noted at the start it's a 6 speed auto. All gears run fine in D and in M when manual shifting the console handle up and down.... but I see where you were going with that. Steering wheel contacts.... like my Wife's Challenger.Does it have paddle shifters?
Yeah, clockspring. Seemed like you were mentioning turning,Nope, as noted at the start it's a 6 speed auto. All gears run fine in D and in M when manual shifting the console handle up and down.... but I see where you were going with that. Steering wheel contacts.... like my Wife's Challenger.
Yep.. seems to go off in a left turn. But also fired the AT light stopping hard straight the last time..Yeah, clockspring. Seemed like you were mentioning turning,
