diesel_lv
Spring is not necessary. Before test running car w adjustments you've made, get a pressure tester from auto parts store (loaner tool) and check system hold pressure at 16psi. Then drive car. If it burps a little, let it cool n then drive again and check temps. 215° is "not" overheating. After initial "burp", if it does, do not add any more coolant to radiator. It should not burp again. Now level is where it needs to be for expansion.Anyone know where to get this lower hose spring?
