I'm in the middle of doing some much needed upgrades to the Charger focusing mostly on handling, one issue is the brakes. My motor produces 15 pounds of vacuum which is enough for my vacuum booster 99% of the time but in certain deceleration situations I have zero boost which will pucker your ***! Yes, I could add a vacuum canister but there's still that possibility and I like 100% fixes so I'm debating hydroboost or manual? I've never driven a classic with manual brakes but have had modern cars with manual brakes and didn't mind them at all, actually liked it.
How is the feel, do you really need to stand on them to lock up the brakes? My only hesitation with the hydroboost is cost and all the messy lines. I've seen master cylinders that claim to reduce pedal pressure as well? Just looking for input.
I already have discs in front and will be adding rear discs at the same time.
