Guys, I have a 505 stroker that is all new. Roller cam, Indy heads.
When my engine gets warm, around 190*, the pressure drops below 20 psi at around 800 rpm. This is the same thing that it did with the old 440. I used this pump because it was new. So, I need an oil pump that has higher output at idle rpms, but not at higher rpms. So my questions are, if I shim the pump, does that raise the idle psi? If not, then I need recommendations for a new pump. I don't want to use a stock style, cast iron pump. I'm looking for something that is maybe billet, but mostly I just need one that puts out more at idle. Thanks
