Fuseable Link Size
Auggie56
11:45 AM
NW Ohio
The local el-cheap-o parts store carries one size that looks like an eighteen-gauge wire and no rating on its package.. I'm replacing a higher amp alternator, sixty-five amp, that will need a higher than stock "f-link". My question is, what size link am I looking for? eBay has several different sizes. Does the length of this wire change anything?
I just found this: "A fusable link" needs to be of a gauge four times smaller than what it's trying to protect.
Are you replacing a 65 amp unit with a higher output unit? How much more? What extra electrical load have/will you be adding?
Mike, this car is bare bones. No high-drain electronics, etc. The Alt I bought says sixty AMP on a slip-in the box.
Thanks for responding.
I do not believe you will need to change the link. The alternator may be larger output but I see no reason it would supply any more current than the OEM unit if you have not taxed the system with additional current demand.
Many thanks for the input.
