Fuel line size on a 1969 dodge 440 HP
Stucat
4:20 PM
Was wondering the correct fuel line size and setup on a 69 440 HP? 5/16 or 3/8". Did the 70 HP have the 3/8"? Would the 3/8" be better? Thanks
IMO.....Original installation was 5/16", U code engine, no vapor separator, The six barrel engine, V code, would be 3/8" with fuel vapor separator and a separate 1/4" vapor return line back to the tank. Just my opinion......
BOB RENTON
Starting in '68, the 440 High Performance Engines and Hemis were factory equipped with 3/8 inch inlet line with the 1/4 inch return line and the fuel vapor separator.
Unless it is an outright modified performance engine, a 5/16 inch fuel line works fine. The factory A990 Hemi race engines and the RO/WO engines ran with just a 5/16 inch fuel line from the factory.
One more note. 68 and 69 440 cars got 3/8" pickup tubes but 5/16" fuel lines.
That's exactly how mine came originally, but when I installed a new tank, I just switched to all 3/8".
My 69 Coronet R/T 440 has 5/16 fuel line with a fuel separator and 1/4 return line.
When the rubber sleeve connecting to the tank had to be replaced on Baby Blue, the shop guys were scratching their heads, wondering what the factory was thinking with the 3/8 - 5/16 combo.
The original fuel supply lines for my 69 r/t were 5/16 front to back. 1/4" return line. I have the original fuei pump off my r/t and it has a 5/16 nipple for tank to pump, 1/8" pipe outlet for a brass 5/16 inverted flare fitting for pump to carb. Never seen a factory 440 with 3/8" lines. 3/8" 6pak carb fuel lines can be somewhat problematic (i've made them), but were never factory.
My r/t has a 3/8 pickup-sending unit (original to the car),but came with 5/16 tank to pump.
I also have the original fuel pump from my '69 GTX, and it has the same set up.
If you don't already have a return line and are not looking for a concourse gold car, it is easiest to add a 3/8" line and make the existing line your return. Just need to change the fuel sending unit to accept both lines and add a dual outlet fuel filter.
I still have the OE 5/16" fuel line from my U code GTX....I upgraded to 3/8" just to be sure it wouldn't starve. :)
Nobody knew the difference back then in 2001 when I restored the car. :rolleyes:
Anybody ever have any trouble with that vapor separator fuel filter? It seems like if the car sits for 2 or 3 days you practically got to pour gas down it to get it to start up
Is there any way I can bleed fuel pressure back to the tank more than it should?
