- 10:55 PM
- Jul 1, 2015
NO...it depends on pump design and pump RPMIs the volume in the block equal to the volume in the radiator at all times?
BOB RENTON
How did you make that determination??....what is your criteria...or are you just guessing??No and there is no real basis across the board that it need be.
Answer post 58, please.Post 57
This thread has become tiresome, IMO.
440 B/B with Griffin 26" aluminum radiator. FlowKooler pump. I've run Summit's cheapest dual fan set-up as well as the 7 blade Mopar mechanical fan with a shroud at different times. There is no room for a clutch. 180* Robertshaw thermostat. Factory seal at top of radiator to hood. 50/50 coolant mix. 16lb. radiator cap. It did run hotter at break-in but never overheated. Holley Sniper2 EFI allows changing A/F and timing while driving. I live near Sacramento, CA where 100* days are not uncommon and 90s are the norm in the summer. The car runs at 190* most of the time. Cooler days it runs about 180, 105+ days 195-210. I do have a coolant recovery set-up and leave the coolant level in the radiator about 1 1/4" down from the top of the tank. I drive this car almost every day. The car had a 22" radiator originally and I modified the radiator support to expose the whole 26" core.How many folks have installed the FlowKooler high volume water pump in a car with a big block and 26" radiator?
Already have. I posted about it. Maybe in a similar thread.I have yet to use a Flowkooler brand, it I have used three edelbrocks that have an improved impeller that purports to have the same sort of benefits as Flowkooler. My current 440 car has factory ac and the 26 inches of course. Since this is my third car with the high flow pump, I’m seriously doubting you are being dragged down by your water pump.
You mentioned somebody dumped a can of sealer in the system. If you think it’s not cooling that well, I’d be having that radiator boiled again and also the heater core. That is the only fly in the ointment I can see.
Right here....How many folks have installed the FlowKooler high volume water pump in a car with a big block and 26" radiator?
I said it's running cooler somewhere since changing the high flow 180 thermostat to a standard flow 160.I saw you had it cleaned. I’m saying do it again and be sure they rod it out this time. It’s really the only stone unturned.
"Running cooler somewhat" ÷ how many degrees???.....5 degrees or 10 degrees or ???? Degrees. Difficult to do calculations without numbers.......or just some more "seat of the pants engineering"?????I said it's running cooler somewhere since changing the high flow 180 thermostat to a standard flow 160.
You tell me. The ambient temperature went down about 5-10 degrees and the car ran about 5 degrees cooler once I got it up to temperature by driving around with the AC on. Before, the temperature was always about 195-200 flung in gear at a stoplight with the AC on."Running cooler somewhat" ÷ how many degrees???.....5 degrees or 10 degrees or ???? Degrees. Difficult to do calculations without numbers.......or just some more "seat of the pants engineering"?????
BOB RENTON
