measuring piston to deck clearance on 440 source dished piston
If I had a way to measure the actual deck height it would answer some questions. How much was the deck cut at the first shop? What is the actual deck height now?
My guess, the first shop zero decked it. Then after the thing popped out a freeze plug and cooked the engine they had to cut it some more, along with the heads. Then they had the pistons sticking out of the holes and sent it anyway with 12:1 compression.
I dont have the stock crank, pistons and rods or I would put them in and measure where the stock pistons are at now.
I have a couple of comments.....
. the stock head at 78cc is, 11.06:1. No wonder it detonated itself to death in 5000 miles.
How heavily milled was that stock head? I've cc'd a few and uncut open chamber heads are often near 90 ccs, I had a few come in around 86 ccs after a few resurface jobs.
I seem to remember Kern Dog trying alp kinds of things to get his stroker not to detonate. He finally solved it. HE STUCK FAT HEAD GASKETS IN IT.
Oh yeah...I was close to 11 to 1 with aluminum heads and with anything less than 110 leaded gas, it would knock. I tried several things to eliminate the knocking but it wasn't until I went with thick head gaskets that the knocking stopped.
Not sure what KD had going on with his engine. We’re discussing Paul G’s engine.
Yeah, but like anyone smart, 33 looked to things from the past to solve a problem in present day. This is something that seems to be LOST on some people today. The reason we study history is to try to avoid making the same mistakes over and over.
Someone has cut the deck quite a bit to be proud 0.012”.
440Source pistons are measured on the large flat surface - NOT the bottom of the dish or any raised portion. Yes, you want to measure on the pin centerline or close to it - if that means at the edge of the piston that's fine.
FWIW the pistons on my 526 are .016 out of the hole - they should have been .009 IN the hole !! Since my block was not finished for MLS gaskets, I used .062 SCE copper gaskets with a stainless fire ring in them. NO issues.
I have Indy aluminum heads. I figure compression is around 10.5:1 - give or take. I run 36* advance and 92 or 94 octane unleaded gas.
Its worth noting that all the compression numbers piston manufacturers give are based on the block manufacturers "blueprint" deck height and stock gasket height with the cc volume of whichever head you're running. So to achieve the advertised compression ratio with a specific head you have to adjust the head gasket thickness based on the piston relative to the final deck height. In a nutshell, you want the head mounting surface (including the gasket) at the same height a stock head would mount. Block deck surfaces should always be measured. Any deviation + or - should be corrected with the head gasket.
If the pistons are a true .012 out of the bore I would .050-.060 hg. And have the chamber in the heads and the dish in the pistons enlarged to get to the desired cr. More than .050 quench distance your opening the door to detonation again.
Personally I believe quench is overrated. Does it help with detonation, yes. Will it overcome insufficient fuel octane, poor chamber design, compression to high, camshaft to small? No. Is there is a difference between a .038" gasket at zero deck vs an .050" gasket at +.012" deck? Yes, the positive deck will have the dead area above the ring closer to the deck which is a small benefit, though very little. In this case that compression would still be too high. I'd run the thick gasket and get the compression down. At tthat point it won't care if it has quench. Many race motors run no quench. Especially boosted and nitrous stuff. My race motor runs zero deck at 15.1-1 with a .060" gasket. Just have to match the fuel to the compression ratio. In this case 10.3 using an aluminum head on 93 octane will never detonate.
I dont know how much was cut from the heads by the first shop that screwed it up. The machinist who has them now is going by cc volume. One head was much less than the other. I am calling him today and will get the actual numbers.
I like the “buy a new bare head” plan(as long as the head to be reused is still close to 78cc’s).
Pair that with the 27cc piston out of the hole .012” and a cometic .051” gasket.
(I get 9.93cr for the above combo)
Now for degreeing the cam. It wants to be on 108 ICL. That's where I put it last time. It was not straight up to get it there. I don't remember if it was advanced or retarded, but I think it was advance. The torque down low was outrageous. I would like to move the power up the rpm band and loose some of that torque down low. That would mean to retard the cam this time, which would change the ICL right. Is that ok to do?
Your cam card should tell you if there was any advance ground into it.You should be able to retard it that much. But I Be sure to check piston to valve clearances.
Note: mopar built millions upon millions of engines with no quench whatever..
And when 'mom' started dropping CR's for lower emissions the no quench engines pinged and dieseled themselves to dead.
How bout a different cam....one that bleeds off compression in the lower rpm ranges but builds some compression in the higher rpm range when the engine is turning fast enough to not have to worry about it if pings because there's not enough time for it to happen.
This is the cam I have
Lift - 543 int 540 exh,
Dur - @50 234 int 240 exh.
112 LSA
108 ICL
Paul, you can put that cam in anywhere you want. I personally encourage you to experiment, and learn something. Understand that you will get a lot of opinions from folks that have never done it.
Checking PV clearance is always a good thing.
Paul that cam has 4* advance ground into it. Straight up would be ICL @112*. With your 500ci and a potentially high compression ratio (did you ever get that figured) I think straight up would be beneficial or you could split the difference at 110.
Edit: I have no experience installing cam on 112 ICL. I have most always installed around 108 to maintain bottom end power. Because all of my engine builds or <400ci
I just went through a cam degreeing video from Britney. Link below. With the cam straight up the ICL is at 90, i want 108 asper the cam card. That is 18° retarded. This kind of rings a bell from the first time I did it. I think back then I had to advance the cam 4° to get the 108 ICL. Does that math sound right?
Also I checked intake valve lift on #1 piston. I came up with 538?? Should be 543. This a Summit brand degree kit. Not pro quality. And the #1 intake lobe lifter is hard to get the dial indicator on straight. And its me doing it. Fat shaky fingers and bifocals.
This car was a real SOB to get off the line. When the clutch grabs the tires go up in smoke. Not as bad with slicks on the track, but on the street it is just a smoke show. Killing some of that low end torque for more RPM up top is not a bad trade off IMO.
The grand kids have some playdough around here. I can grab a little tub.
Folks have two different definitions for “straight up”. One is straight-up is what the cam manufacturer recommends for the ICL, the other is straight-up is ICL= LSA.
You just need to be aware of this when you read responses.
Straight-up is such a terrible word choice for this.
I am going to CC the heads myself when I get them back. Like Ronald Reagan said "trust but verify". Then I will know exactly how much head gasket I need. I expect to be around .070"
It is installed dot to dot. That is how I took my measurements.
Straight up is a bad term, but dot-to-dot is worthless.
