Fuel Line Flare
* if you make your own lines.. get nickle copper... OMFG..... i didn't listen and when i finally did it is soooo insanely easy to work with compared to steel...
Yes, used that stuff for my brake lines. So easy to bend. I have the harder stuff I had used for fuel lines so I'm gonna reuse most of it but utilize rubber hose for the trickier bends and running to the carb. Sounds like I'll go with the bubble flares for those unions. I have an old style Rigid brand flare tool that works well. The modern import copies are junk. Cheap metal and lose tolerances.
Thanks Guys for the info!
