Well, that was short lived - about 10-12 miles - and then back to squealing. I’ll pull the belt off and soap it down and try to rig up something better to sand the groove on the lower pulley.
My 1968 GTX with AC has belts squeals because I don’t have the 1968 power steering pump brackets on it (I have the 1969 version). I have the correct brackets now, but not installed due to a rod knock that developed a few years ago. Good luck with your issue!Well, that was short lived - about 10-12 miles - and then back to squealing. I’ll pull the belt off and soap it down and try to rig up something better to sand the groove on the lower pulley.
Was it rpm sensitive as mentioned above or a constant squeal?I have the same belt setup on my 67 383 with PS and A/C. I had to replace the idler pulley several years ago because it started making a noise that sounded a lot like a belt squealing. Checking the belts, I noticed that the idler did not turn smoothly - the bearings were going bad.
That is probably the source of my belt squeal. All new pulleys from Bouchillon Performance Engineering are powder coated. Only squeals above 2300 RPM.Many years ago I had access to free powder coating and everything went to the powder coaters including the crank and water pump pulleys. Man did they squeek.....
View attachment 1944470View attachment 1944471
Are the contact faces of the offending belt glazed at all??? Or are there cords showing on the faces?Going back to trying one of my old Quanta’s show poodle old-style belts to see if it helps.
Soaped it up good first. Will see what this does this afternoon.
I’ve accumulated a good number of unused and low use belts by now.
I'm curious where you found the weird conversion chart that shows a 3/8" to be 15 millimeters.The belts are all 3/8” (15 mm) except for the PS pump which is sized for a 1/2”(17 mm) belt. Those are the stock belt sizes for the year. I tried fitting a 1/2” belt on the water pump pulleys but they stick out of the pulleys quite a bit. I’ve been running Dayco Top Cog belts but I switched back to one of my old Quanta’s Mopar Restoration belts on the water pump to if soaping its sides might fix it.
and 1/2" to be 17mm.I'm curious where you found the weird conversion chart that shows a 3/8" to be 15 millimeters.
