chargervert
I am doing a rear disc brake conversion on my 70 Charger. I bought the Right Stuff rear disc brake kit. I also ordered the green bearings to replace the factory tapered roller bearings . I noticed that the green bearings come with a spacer,and I am assuming that the spacer goes on the axle first, then the retaining plate,then the bearing with the snap ring towards the hub of the axle. Am I assuming correctly? I am going to take the axles to have the green bearings pressed on,and I want to install them correctly the first time! The axle is a Dana 60. Thanks Pete,
