1964 Plymouth Savoy Build
Ok earlier I mentioned I was going to use Edelbrock Carbs, but recently found a pair of Carter 3705 S carburetors and I'm very pleased with them. These will give me a more authentic look. Going to take the tops off and check the float settings and document the jetting. Hope they work well
Last week I finally got the time to go over the Carter 3705’s I got for the car. Want to check the Butterfly screws to make sure they are correct and secure. Did want anything falling off into my fresh motor. Found one secondary screw that didn’t look seated all the way in and when I just touched the screw head it broke off. They are brass screws. Also I notice the same carb didn’t have the choke plate with the vacuum pull off valve. I found new replacement ones on line along with new replacement screws. Drilled and taped all the screws out and removed the shaft. Cleaned it and made sure it moved smoothly because before it would stick and the spring did not have enough tension to close it. Probably because the butterfly valve not centered because of screws. Got it all back together with the new parts and gaskets. Set the float levels to 7/32 with new needles and seats. Paid a lot of money for these and still had to go through them but I want them to be right.
027EA233-C9D4-4D37-8D35-96F2218CAD2F.jpeg 8F16472F-B89C-4DE3-BB47-13313EF21388.jpeg F26BA9C4-6B56-440D-9641-7BE8EB5AC484.jpeg 20F5B955-CA5D-438D-8190-678CB2DE10AE.jpeg A4E691D8-E080-4652-B41F-EF13FE66797F.jpeg 750A634C-AB96-4F04-A115-51CB49138BF2.jpeg
Now I was inspecting the second one and found a big problem. Both of the mixture screw’s ports castings are blown out. Obviously from someone over seating the needles too far. So the lower housing is junk. Im getting another 3705 lower housing sent to me and hopefully it not like this one. I’ll know tomorrow when it arrives.
A7360B85-7D58-4F6E-B693-4ADD6796EAEB.jpeg 7C523ADD-B6E7-4A0F-AA00-7DE07C347EEE.jpeg 2F4FC8F8-4EA2-4B4F-B314-263FCA29A1D5.jpeg
Got the replacement lower housing for 3705 Carter and transferred all the parts to it from the other damaged carb. I also took not of the jetting, they are staggered with the left side with slightly bigger jets. This one also got all new gaskets and accelerator pump, made sure both had Orange Springs.
68751E46-F3C2-46F0-80B1-428240384622.jpeg 0C483AA2-1374-43A4-B2D9-3E554F197D39.jpeg 80960790-01B9-4E02-9B94-9316892C1467.jpeg D5149E21-5787-4FC1-9960-3009B4163973.jpeg 5AD33DE5-FE1D-456C-8E99-A866A29E1B9A.jpeg
Mounted the left carb first then mounted the right. Connected fuel lines and throttle rods. Need to get a choke cable and velocity stack’s to finish it up. Will keep you posted on that
45733BE9-2242-4478-9F03-72423E3EE333.jpeg 0D40A7B2-03CF-430E-843D-F792CC967E47.jpeg E215DDE3-759B-457F-80B5-DBD7BF2B3EE5.jpeg 0EB0672A-71FE-49AF-8F96-70BAE4CA6547.jpeg 005078AC-B567-4F62-8E33-04F33F19DDCE.jpeg
Gorgeous !! But I think you'll find that the large rivet radiator cap is incorrect for '64 and should be the small rivet style. Large rivet started on '70's.
AMD sells the correct cap but I'm sure there are others.
That I wouldn't be so sure of, they list both as '64 and up and unsure of their source. Richard worked to get correct small rivets made with some others. Jamie at Megaparts has them for sale as well and would be my supply choice, with Richard on the sidelines currently with other obligations.
