I've already bought one to use as a temporary tank with the hopes of finding a suitable used tank
A common problem with the threaded upper control arms since the threads are so minimal and often strip. The weld makes sure it doesn't go anywhere. Common issue and common solution!Here's a good one the upper ball joint has been welded to the control arm. That's a no-no!
View attachment 1942787View attachment 1942788
And mines a 74. So there you go.Control arm/BJ issue is also commonly caused by people who assume they are pressed in and press them out.
They DID change to press in BJ's but IIRC it was during the 74 model year.
Already have the dynomat on hand.Perfect time to start applying some sound deadner...
Can you elaborate?I might suggest a sector support addition to the bottom of the Pittman arm to stabilize that.
Can you elaborate?
Where did you get that?A sector support kit looks like this:
It has a fitting that secures the Pittman arm instead of the standard nut (Pittman arm not shown in this picture).
The bearing has a bracket that attaches to the K-member to keep everything solid. This is what keeps the steering box/ Pittman arm from flexing.
Note that the pictures above were taken when I was mocking this up in 2015. The Pittman arm is not shown in the photos since I was drilling and fitting the assembly. In the last picture especially, you can obviously see the splines in the steering shaft where the Pittman arm attaches.
Hope this helps.
