Daves69
Well today I pulled the pump off to have a look at it and the pump looked fine. But did notice the cap for the pressure valve was a little loose. Tightened that a put it back on. Primed it and I was a getting some pressure on the gauge. But ran out of time, I'll start it up next weekend and see if the pressure is back to normal. FYI, I have an aftermarket milodon external oil pump.
I could be wrong but I don't think "a little loose" would translate to zero pressure. Then too, with no broken intermediate shaft, what's left? Rotor possibly spinning on the rotor shaft similar to having a spun prop on a boat? Maybe you should mark it before you fire it up again.
