440bb 40psi cyl6 not firing help!!
TruckManiaMike
6:17 PM
California Maryland
Just got this motor and it sounded a lil wonky. Might be cammed not sure what’s been done, has a Holley street dominator intake manifold, 600cfm Edelbrock carb, and long tube headers. No fire to cylinder 6 definitely have spark because i used a spark tester at the end of the plug. just did a compression test (cold motor all plugs removed full charged battery throttle wide open tested one cylinder at a time) here’s my results in psi
8-160
6-40
4-120
2-120
1-150
3-90 hears psh noise
5-150
7-170
Run a leak down test. You could also pull the valve covers and inspect the valve train. If compression was ok I would be looking at the cap as 3 and 6 are next to each other.
Should be but why???
Someone couldn't count to 8?
I would also get a light and inspect the top of the lifter if you can see it decently to check if the socket is ok, and nothing has come loose
