'74 k member questions
bhemi
8:24 PM
Vancouver
I'm finally getting around to a '74 SSP with a 400 I bought a couple of years ago. The rear drivers side part of the K member has some pretty good rust damage. I have a '74 parts car with a good K member but it had a 318. Can I swap the K member and just change the motor mounts? If I can't is it possible to cut out the bad part and use the small block K member as a donor? Or do I buy the Schumacher engine mounts and be done?
Easiest way is to get the mounts. You would have to cut and reweld the drivers side mount on the small block K frame for the engine to sit correctly.
Mark
