I was watching Graveyard cars and realized we left out the oil slinger on our bb stroker build. what is the dangers we face, got a couple thousand miles on it
Front seal is just more likely to leak. It does deflect oil spray to the chain as well, but the oil spray probably hits the chain and lubricates it anyway.
As I recall, when Chrysler started using the double lip seal design, the slinger was deleted. It was originally designed to work with the single lip seal.
Mike
Just thinking out loud here and maybe I'm all wet here so please don't shoot!
I suspect the "slinger" as being more of a baffle as there in no real slinging feature to it. Does it not make sense that it deters hot sump oil from rushing to the lip seal of a rotating crank under braking. There is a "slinger" on the crank rear as well. Where does that "sling" oil to?
Mike
