Mike67
Beautiful work Jimi! I envy your skills!
I dont know what happened to those, why they got so reduced because they were taken with good cameras & used to display larger....just have to zoom them.....most of my stuff is in hard albums....dont have that much downloaded...why i keep posting same.We need bigger pictures!
Thanks Mike! camera dates incorrect..this piecewas completed in 2014...is one quarter of what was cut away from the Crucifix Blade....That's the deTomaso logo inscribed above the grip area....& yes, One could be seriously hurt with this. CalledBeautiful work Jimi! I envy your skills!
You are a true artisan, and master craftsman....beautiful work!Thanks Mike! camera dates incorrect..this piecewas completed in 2014...is one quarter of what was cut away from the Crucifix Blade....That's the deTomaso logo inscribed above the grip area....& yes, One could be seriously hurt with this. Called
the Bettie Frances Mangusta 1148...Bettie is my Late Mother, Who lost Her Life to a rapist in 1969(its accurate to assume i was projecting on this carving)...8MA-1148 is the deTomaso Mangusta i owned once upon a time....401 hand built
View attachment 351566 View attachment 351567 View attachment 351568 View attachment 351569 View attachment 351570 View attachment 351571 View attachment 351572
The hood is a 67 GTO convertible i did a ton of work on...a rotiss pro touring mod....molded the scoop extension in & opened the intakes so it"s functional. View attachment 351574
It's a Ruskie built plane.
https://en.wikipedia.org/wiki/Beriev_Be-103
http://www.sukhoi.org/eng/planes/civil/be-103/
"Hush hush, thought i heard Her callin my name...hush, hush...."
View attachment 351361 View attachment 351362 View attachment 351363 View attachment 351364 View attachment 351365 View attachment 351366 View attachment 351367 View attachment 351368 View attachment 351369 View attachment 351370
For the plex & paint..3-M 05976 "Perfect IT ll" light tan "MECHANICAL" compound(NOT perfect it lll!!!!)Just for curiosity, what do you use to polish a plexiglass windshield?
CORRECTION...i got the numbers wrong on the compound...Quarts are 05973....Gallons are 05974. Qts are about 35.00.....Qts of the 05928 Finesse-It are about 70.00.
I got the Perfect-It ll #'s wrong...Quarts are 05973....Gallons are 05974. See my repost to RC for a bit more info on productsFor the plex & paint..3-M 05976 "Perfect IT ll" light tan "MECHANICAL" compound(NOT perfect it lll!!!!)
a very mild abrasive........mixed with 3-M 05928 "Finesse It ll white creme glaze) i mix approx 70% compound to 30% glaze.
Cutting polish is done with wool wheel, followed by foam wheel with sparing amounts of the same mix. Then i follow that with hand applied Teflon....the stuff in orange bottles,,"NU-FINISH" is Great Stuff.
This windshield & cabin windows i've posted...the "Speedslope" windscreen was crazed(tiny fractures on surface that go prismatic in direct sunlight) so i started in 120 grit on D/A, followed by 220. Then Wet manual sanding using Firm but pliable pad, starting with 400, 600, 1000. Then the polish procedures. Cabin glass was smeary, cloudy, scratched up, but no crazing...so i hit the exteriors with the wet sanding process, same grits. last four panes in cabin are double pane..so interior panels came out to separate glass, so all interior sides of glass were polished including back side of windshield.
Acrylic Plex i can can get crystal clear.....poly carbon is a muther to get the milk out of.
Also....NO Hi Speed!! just creates friction, heat and doesn't cut any faster...think of drilling a hole....whama-jama just hogs at the metal & wears the bit out. I NEVER spin my wheel faster than a 1000 RPM, usually holding it down to 500 RPM. NO HEAT! ANY medium....dont try to work in direct sunlight....keep everything cool.
So the same compound mix was used to bring the paint back as the plex on the Grey Baron....the 1/2" satin black trim @ glass edges is my deal & there is an 1/8" black silicone seal @ glass edge...black on black.
Everything is for sale Ski....well Almost everything.Jimi, Cool gas pump!
Is that for sale?
Yeah,,i'd love to see that brought back top, then it would be worth installing more....the filler is the bomb btw....i will NEVER spread bondoe again, that is for certain...18 Tons...the press was leaking, so couldn't get past 18 tons...the puck only compressed 30 thousandths...no fracturing. ROFLMFAO!Jim, info like this would probably fit in your bodywork and filler thread as well. Great stuff!
I digress....i guess Pete wants to hang on to the pump. SorryJimi, Cool gas pump!
Is that for sale?
Nice pump
