Ski 61701
- 7:56 AM
- Nov 21, 2016
- Bloomington Illinois
Ski, I do have an IR heat gun I borrowed. What I need to know is what temp readings should I expect to see at the locations you mentioned? And what would be considered too high?
Like others have mentioned, you should see definate temp drop from top hose to rad and bottom hose 30 degrees I would say would be good. Yes definately take measurements at all 4 corners of the block and heads and record everything. Do your temp readings after a couple of mins of run time, and once thermostat opens. So you are going to be busy. By chance do you have spring in bottom hose? So it doesnt get sucked shut at higher speeds. Also, some rad caps are designed to be used with recovery tanks. For grins just try yours turned down to first notch enough to keep fluid in but will not create system pressure. Recheck temps doing this method. See if there is a difference.
While you are checking temps, another test would be to manually turn on coolant fan and see what inlet and outlet temp of radiator is. I would think if you have minimal temp drop from top to bottom of rad the cooling fan is not working as designed... at least for your car.
These things are a royal pain... I've been in your shoes. not sure if you've done this, make sure distributor advance is not stuck and weights move freely.
