- 10:14 AM
- Feb 20, 2012
- New Hampster
Headers aren't worth the aggravation for a street car.
But they are easier to find than a set of hp manifoldsHeaders aren't worth the aggravation for a street car.
Gonna disagree, and explain. I think it depends on engine. Examples:.....Headers aren't worth the aggravation for a street car.
Pffft!Headers aren't worth the aggravation for a street car.
That is odd. My TTI headers cleared my manual bell just fine.I run Doug's Headers. 2" primaries. My bell housing also does not fit between them. So I have to slide the tranny back, then lower, then back, and so on until I get to the widest part of the header, then rotate the tranny about 30 degrees, and down she comes. I'll post a pic when I get mine installed, hopefully before 2025.
The TTI 1 7/8 and their 2" pipes should theoretically be the same aside from the pipe diameter but they are quite different. I don't understand why.
My 2" pipes clear the Fast Ratio steering arms while the 1 7/8" pipes do not.
I only ordered these because they were out of stock on the 1 7/8" pipes when I was ready to buy. I've believed that header pipe diameter should be close to the exhaust valve diameter.
Chuck a quart in and warm up in neutralOh boy, this is what I am facing right now. Transmission rebuilt last year has only about 25 miles on it. Drove the car into the garage last Thursday evening and Friday morning it wouldn't move in any gear. Fluid is out of the bottle clean without any residue. Cooler lines and cooler are not plugged up. Sounds like my TQ probably gave up the ghost
Seriously doubt it's a convertor problem... Check the shifter linkage.... No single band or clutch failing would take out every gear.. But a linkage problem sure will... When you take it out of park can you push the car? Or does it stay in park? sure sign of a linkage problem... But even if it rolls there can be a problem where the main control valve doesn't move... If the external linkages look okay, drop the pan & see if the manual valve is separated from the rooster... See photo...Oh boy, this is what I am facing right now. Transmission rebuilt last year has only about 25 miles on it. Drove the car into the garage last Thursday evening and Friday morning it wouldn't move in any gear. Fluid is out of the bottle clean without any residue. Cooler lines and cooler are not plugged up. Sounds like my TQ probably gave up the ghost
The fluid level does not change regardless of being in neutral or any other gear. It remains at the same level. So, adding another quart is not something that makes any sense, diagnostically speaking.Chuck a quart in and warm up in neutral
Easy way to see if it is a pump issue is to disconnect a cooler line and crank.it over while watching to see if fluid goes into a pan from the line. If it doesn't then your pump isn't engaged or functioning.The fluid level does not change regardless of being in neutral or any other gear. It remains at the same level. So, adding another quart is not something that makes any sense, diagnostically speaking.
Absolutely not true... If the convertor leaks down the stick will read over full even with the engine running & the shifter in park... When you put the trans in neutral or any gear the fluid is re-directed from the discharge of the front pump to the convertor... In park it leaves the pump & is sent back to the pan... So if it reads full but the convertor isn't full the trans will be low on fluid when put in neutral of in gear... There are aftermarket manual shift valves that allow the convertor to fill in park but stock that's not the case & because of that the fluid level can change when shifting from park to neutral...The fluid level does not change regardless of being in neutral or any other gear. It remains at the same level. So, adding another quart is not something that makes any sense, diagnostically speaking.
