Clear heater hose specs- PSI; max temp etc
munger77
10:32 AM
Atlanta, GA
found clear and blue heater hose on Amazon with 5/8 in internal diameter; rated at 70 psi and 350 degrees F.
Not sure if it is good enough for my 68 gtx with 440 in it. It says safe for water and AF.
I like the idea of clear hoses running antifreeze through them. Thoughts?
Water temp should get above 275 worst case unless you have something catastrophic happen. PSI should be no more than your cap, 16lbs.
I’m good with the stock setup.
Thanks 69L; I’ll buy an 8-10 ft section off Amazon - much appreciated.
