- 10:11 AM
- Feb 20, 2012
- New Hampster
well its been a while got most of the wiring done, sleeved the new harness with shrink wrap gives it a little protection and looks good, also sleeved the vacumn lines for the booster and headlight doors. Got instrument cluster back from instrument specialties, fantastic job still need a rocker arm for my three speed wiper switch, figured I'd test it to see if I need the switch too! carpet went in without a hitch, laid done pretty good ended up putting own some sound deadoner/ insulation, floor board looked so good I didn't want to cover it but the advantages seemed too good. and no I still haven't blacked out my tail panel. was gonna try to wrap it with the tail stripe, I was informed that it will contour to the shape with no problem and I can get the stripe and the tail panel cut from the same material so it will match perfect, And if I don't like the blackout it can be removed easily. the insides of the doors I masked off and painted, BIG improvement looks way better black. the American one autowire kit is a little overwhelming when you first open it but doing it one step at a time it went pretty smoothly. no more ballast resistor one wire alternator, grounds for everything heavier wire where its needed and fused hook ups for anything you wanna add. everything is plug and play with exception of your end wires to most everything but then you can customize your lengths and how they route and lay down and yes, buy there crimper if you go that route. picked up some 18" American racing rims and tires from a southern boy in west virginny on my way back from tennesee. thanks Sam! also picked up some 305 nitto drag slicks for my beaterView attachment 613811 View attachment 613813 View attachment 613814 View attachment 613815 View attachment 613816 View attachment 613817 View attachment 613818 View attachment 613819 View attachment 613832 View attachment 613820 so I can have a little fun this summer.
Same color scheme as mine. You're really going to like it, Hellcats are a blast!
,but thats way cool can't wait to see it saturday. I just got my motor back have been setting everything up on it so it will save me from leaning over under the hood, was gonna wait a while before posting some new picks but, here's a few shots
