I have a mostly complete '71 383 Charger that my daughter recently bought me as a retirement project. My plans are to build it as a street legal, stock interior, bench seat cruiser with an outer mid '70's dirt track theme. Car sitting low with big tires and wide rims on all 4 corners with big radiused wheelwell openings. M&H dot drag radials look a lot like dirt track tires, might even install wide 5 spindles/hubs, 4w disc brakes, maybe an old quick change.
I am only semi-retired, still making my ClutchTamer and Hitmaster products for drag racers. I ran BB Mopar powered Outlaw Dirt Late Models with backwards mounted engines starting back in '85, so I stll have a soft spot for dirt track cars. Here's a pic of one of my backwards engine cars without the body installed...
The headers are a set of Tri-Ys made by my friend Hank Young, he was one of Doug Thorley's first employees and had made countless sets of Tri-Y headers. My homemade transmission was hung off the off the former "front" of the engine, I still have that little homemade bellhousing under a bench out in the shop. That transmission's input shaft plugged into a home-made coupler that bolted to the harmonic balancer. A couple extra "keys" were added between the balancer and crank, just simple holes drilled along the parting line with some dowels installed. The drivetrain was "reverse rotation" with the engine installed backwards, which required me to modify the QC rear to put the ring gear on the other side of the pinion. I always had more time than money, this car even featured widened steel wheels and home-made steel beadlocks.
As far as I know, it was the last BB Mopar to win a feature at my local speedway.
Here's a pic of the last Outlaw Dirt Latemodel i built back around '95, it was powered by 2 Mazda rotary engines bolted together...
Grant
