Electric fan sensor
TN Mopar
3:43 PM
Cleveland TN
For those of you that are running electric fans, How did you run the temp sensor?
I am considering a swap to electric fans but I don't want to lose the Temp Dash gauge
This picture shows the factor temp sensor and the plugged hole on the oposite side of the radiator hose
How do I run the wiring and sensor for the electric fans?
bumping this
I am still hoping to get a few more options on how to do this
I just used a manual switch for mine to not interfere with the temp gauge. Simple wiring with the switch hidden under the steering column.
@andyf had an adapter that goes below the thermostat I believe on one of his cars and has a port to install a temp sensor or temperature switch. A pretty clean solution.
Many of the factory cast iron water pump housings had an extra pipe plug that was unused in many models.
As far as wiring if using a switch you should still use a relay to power the fan motor.
The temperature switch pulls in the relay.
A 20 or 30amp fuse would be required.
