Exhaust pipe clearance.
c.moo
12:22 PM
tennessee
What is the exhaust pipe clearance between bottom of floor to top of pipe or what is recommended ? Thanks
Factory? Several inches. Custom exhaust? I’d say maybe 2” (?) 1” seems a little tight to me
Factory specs , Mopar had this figure out the right distance to put it from getting to hot inside and melting and blistering paint and undercoating and beating floor up and hanging down to low . Couldn't find specs on it . Yes , I could put it anywhere but like to know where factory had it . Thanks
Even with 3” pipes there’s an air gap of 2” or more between the floor pan and the exhaust.
The rear hangers at the mufflers will pretty much dictate the rear section and the header or down pipes will have the front.
Then I think you'd have to measure those points off of a car of your same engine type with factory exhaust and measure it.
Thanks everyone for your input , going to go for 2 -2 1/2 inches somewhere around there should be fine , what I seen or heard is about right . Don't hear of anyone having problems with that space in between floor and pipe .
