Do you all go to Kil-Kare, National Trails, Edgewater or Indy during the course of the year?Milan is the closest at 1hr away.
Definately be at Trails for the NSS Bash. Either Indy NMCA or the Mopar event at Norwalk.Do you all go to Kil-Kare, National Trails, Edgewater or Indy during the course of the year?
WTF? Not a racecar? Are those judges blind??As it turned out John's 64 was moved out of the racecar class. He was told it had to much "detail" to be a real racecar. Won 1st plae and 2 other awards anyway. It'll be at Milan testing in April.
I go to the US Nationals every year & try & do bucket list track. My very first National event was Spring Nationals @ National Trails 1978, kinda have a soft spot for that track. Norwalk, what a great place & well ran, great place for fans & racers. Will have to look into NSS, to be honest, never seen or heard about it. Nothing better than Nostalgia Mopar drag cars. Best of luck racing this year. Appreciate the information DougDefinately be at Trails for the NSS Bash. Either Indy NMCA or the Mopar event at Norwalk.
Doug I imagine the Polara is quite a bit "girthier" than your Plymouth?Ernie Miyamoto from Motofab inc. 2 1/8" - 2 1/4" stepped, 4" collector. It'll be interesting to see how it runs vs mine. His is 540" vs my 580". My headers are 2 1/8" with a 3 1/2" collector. Both have similar compression, cam, carbs, intake. He has 572-13 heads vs my -1's. His is an 8" converter, mine is 9 1/2". Both 4.10. 1 run 10.5x31. His is 10.5x29.5. His motor should keep making power past my 7000.
What Johns Dodge has going for it; KB aluminum block vs my 275lb Mega block. John weighs 140 to my 200. Front and rear glass bumpers, glass fenders vs my steel bumpers and fenders. Kirky seats are 8lbs lighter than my Homemade seats.Doug I imagine the Polara is quite a bit "girthier" than your Plymouth?
Damn beautiful car.
The weight advantages or disadvantages may be a surface conversation, but that car as beautiful as it is, still has to iron out the new combo kinks and not get drunk over its own power out on the groove.What Johns Dodge has going for it; KB aluminum block vs my 275lb Mega block. John weighs 140 to my 200. Front and rear glass bumpers, glass fenders vs my steel bumpers and fenders. Kirky seats are 8lbs lighter than my Homemade seats.
What my Plymouth has going for it; Car itself is 4" shorter. Sedans are lighter than H/T. Chrome moly cage vs d.o.m. steel. 5 gallon cell vs 15 gallon. Steering shaft and strut rods are tubing. Billet Specialties wheels vs cast Torque Thrusts. Rear window is lexan vs stock glass. Carbon fiber lift off hood vs hinged fiberglass hood. Mine doesn't have a backseat, console, front window regulators, or pot metal gauge cluster in dash. The cars are virtually identical otherwise. His physical weight along with the block, fenders, bumpers, seats, and block give him roughly a 280lb head start. We will weigh both on the same scales in a few weeks. It could be very close, maybe even lighter. My bet is I'll be about 3290 lbs with driver and full 5 gallons of fuel race ready.
True John has never been quicker than 11.3 so it's going to be a slow learning curve.The weight advantages or disadvantages may be a surface conversation, but that car as beautiful as it is, still has to iron out the new combo kinks and not get drunk over its own power out on the groove.
Hope you advise not to go all out right away.True John has never been quicker than 11.3 so it's going to be a slow learning curve.
Self preservation will likely kick in.Hope you advise not to go all out right away.
Awesome. And you mentioned you wired the car. Is there a specific kit or brand you like?Generic aluminum I believe from Summit. Fans are late model Doge Charger.
I used a ARC switch panel to drive water pump, fans, fuel pump, oil accumulator solenoid. The stock taillight and headlight harness were modified (no firewall plug). The rest is wired with rolls of wire and relays purchased seperately. In addition to the ARC fuse block a secondary new style fuse block was added just below the ashtray. The heater temp control runs the line lock. I like the relays close to what ever is being driven. The fan and water pump relays are on the motor plate. Fuel pump relay is next to the battery. The engine compartment and headlamp wiring is hidden in the right front frame rail.Awesome. And you mentioned you wired the car. Is there a specific kit or brand you like?
